labview excel with activex
Oh i am a bit stupid there is indeed a Sheetname entry, what should i put on it ? the name of the file (ok2 in my example) ?
using labview 2014, beginer on labview
Message 11 of 29
(3,372 Views)
i think i managed to resolve this probleme by putting "Feuil1" (french version) which is equivalent to "Sheet1", but now i have an other probleme:  error -2146827284 s'est produite à : Unknown System Error dans Untitled 1.vi
Message 12 of 29
(3,365 Views)
Hi Louis,
did you debug this VI? Where eactly does the error occur?
Which ActiveX property throws the error?
Message 13 of 29
(3,356 Views)
in the node "application" does the error occur
Message 14 of 29
(3,353 Views)
Hi Louis,
is Excel installed on your computer?
Message 15 of 29
(3,349 Views)
yes it is, maybe something strange, before i was looking on the internet to find a complete VI i tried to use activex to creat all on my own and excel application doesn't appear when i create an activex objet and right clic to insert activex component, excel is not available
Message 16 of 29
(3,361 Views)
think it is in the last close reference that the error occur
Message 17 of 29
(3,344 Views)
Hi louis,
How long you are Using LabVIEW, If you are very new please go through basics of LabVIEW.
I have attached Snippet for your understanding and not to provide you the end solution.
Try to select the Activex ref by browsing and find the MS Excel Ref.
Message 18 of 29
(3,329 Views)
thanks, i have the basis of labview i am using it since two weeks, but not good enought to understand  all of  the vi to write to excel
Message 19 of 29
(3,325 Views)
Try to analyze the code Step by step (use Highlight Execution) and Understand whats happening.
Message 20 of 29
(3,326 Views)
