05-24-2016 08:21 AM
Good morning, I am developing a control program based on using two programs, TIA Portal, Siemens, with a automaton S7-1200 and NI LabView to use various applications, including the monitoring of my program.
The error I have is in monitoring, the program gives me a bug in which for all and the values become absurd, do not know what to do to change it, it has happened to someone who works with labview?
I await answers, thank you
P.S: If a photo or print is required can also try to arrange.
05-24-2016 08:30 AM
05-24-2016 08:45 AM
Well, the mistake that I'm not here of any print it, but I have the normal monotorização, and it through explain what changes when me of the error
The «corrente maxima» values pass the astronomical value of impossible chain of 1000 and such Amps when the maximum registered by the automaton is 15 except in a motor, start-ups spend exponential numbers, some engines are running for this bug, especially and that appears to me, I know that there is to be something I did wrong in programming labview, because the TIA is all right, the values do not stir ...
Once you get an image of the error and try to take print here, but it's hard because this error is arapido to disappear, lasts for one minute there, you need to walk on the program ..
05-24-2016 08:49 AM
even now I caught the error
05-24-2016 09:55 AM
05-24-2016 10:01 AM
the code is huge, because I have made monitoring, sending emails and still reports to send if needed, and complicated me for it all here ...
only if you want to send only part of monitoring, but still need faer more than a print screen
