labview drivers for agilent e4432b ,can`t find way to control multitone ???
labview drivers for agilent e4432b ,can`t find way to control multitone ???How to deal with it
(3,014 Views)
Accepted by topic author brownheart
Hello Brownheart,
Drivers for box instruments are not meant to cover all applications of an instruments use, only the most common uses. Regardless of discussing whether multitone is a common use for this instrument, a cursory examination of the available functions in the driver does not reveal this functionality.
What you will have to do is create your own config VI using the information from the programming manual of the device. Not ideal, but at least the provided NI driver gives you a starting point from which to add this functionality.
Dan King
(3,005 Views)
Hi Dan,
I am wondering where I can find more examples for using this driver, let's say just some simple functions, like keep changing the frequency of the signal generator over time, etc ?
bo.z
(2,956 Views)
Hi Brownheart, how did you solve the problem?Can you please share? I also need control multitone, Could you give me some examples? thank you.
(2,846 Views)
