labview drivers for Prisma QMS
Dear Gernot,
In case of using the softing toolkit, we have to write the script base program in visual basic or visual studio for establishing connectivity between OPC server (Prisma) and Client (Labview)?
Best Regards.
Message 91 of 95
(1,965 Views)
Hi
No we did not have to write an extra interface for LabVIEW , we used the softing .NET client directly. But we are not aware if the Softing .NET OPC DA client ist still officially available. They mainly moved to OPC UA.
Hope this helps
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 92 of 95
(1,962 Views)
I don't rember the price of Sofing OPC toolkit. It was available a one time payment but these conditions are changing over time.
It was working with inficon QMG 700.
Gernot Hanel
Message 93 of 95
(1,958 Views)
Dear,
Thanks for your reply, it is also connected through visual basic API as well.
Best Regards,
Message 94 of 95
(1,956 Views)
Hi everybody,
I'm a student based in Rome and I'm working on my thesis. I found some issues connecting a QMG220 with Labview.
I'm pursuing two different approach, the first (1) is the one suggested by Pfeiffer's manual https://www.pfeiffer-vacuum.com/filepool/file/software/lab-view/pv_prismaplus_labview_pg0036_en.pdf?... (OPC tunnel connection), and the second (2) one is to use an OPC server client directly from Labview bypassing the tunnel connection.
Here my problems with the two approach:
(1) can't find the exact URL to connect the quadrupole
(2) even if I can can see and browse the OPC items using OPC quick client, i can't browse the tree in Labview.
Thank you in advance for the help!
Message 95 of 95
(1,593 Views)
