09-11-2018 02:17 AM
hello.
Excuse me I want to know is there any way to generate a core in labVIEW FPGA and export from labview to vivado in order to use that in vivado?
09-11-2018 07:26 AM
Hi "nasir70"
We offer what you request for certain hardware targets only I am afraid, and for these targets LV FPGA Module provides the option to export FPGA VIs to the Vivado Design Suite, i.e. allows you to design the exported project and compile it into a bitfile in Vivado and you can then run the bitfile on a FPGA target in the FPGA module.
Read about it here:
http://zone.ni.com/reference/zhs-XX/help/371599N-0118/lvfpgahelp/export_fpga_vis_howto/
Supported hardware includes:
Found this external page that illustrates steps required.
http://fpganow.com/index.php/tag/project-export-for-vivado/
Hope this helps!
09-23-2018 03:17 AM - edited 09-23-2018 03:20 AM
01-10-2021 06:04 PM
I stumbled across this old thread, but want to provide solution if anyone else stumbles upon it.
You can export LabVIEW logic to Vivado since LabVIEW 2020 using "LabVIEW FPGA IP Export Utility".
It generates netlist with vhdl wrapper which you can use in Vivado project for any target (not only NI devices) which use same Family as FPGA Project target from which you have exported.
