03-21-2014 01:23 AM
hai,
iam kinda new to the forum and labview.
can any one tell me how to make RPM measurement using arduino and labview
using the anlog read or digital read blocks in the labview arduino pallete.
03-21-2014 09:19 AM
What sensor are you using? What is the range in speed you want to be able to measure? 0-1000RPM? Answering this will tell you if it is possible with an Arduino or if you will need some other high speed DAQ for reading analogs.
Alternativly the LIFA Arduino library does have SPI and I2C support so if you have a sensor that communicates with that protocol you could read it using that too.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
03-21-2014 11:42 PM
thanks for reply..
i want to use ir sensor and photo detector and the max speed is 2500 rpm.
can you tell me the logic how to write a VI and post VI if possible.
03-22-2014 04:24 AM
