labview FPGA 2012 the compilation cannot be performed by the compiler worker
I am using labview 2012. i have installed FPGA2012, labview2012 FPGA module xilinx tools 10.1, LabVIEW FPGA Driver for Xilinx SPARTAN-3E XUP, LabVIEW Realtime 2012.
i am not able to complie the code. i am getting these messages
(2,467 Views)
Is this the first time you are trying to compile? Has it worked before with another hardware?
On the other side check this link that talks about the issue you are having, it talks about the necesary software to compile and a couple of troubleshooting steps:
http://forums.ni.com/t5/Industrial-Communications/The-compile-worker-cannot-perform-the-compilation/...
Let me know how this goes in order to continue helping you.
Luis G.
(2,419 Views)
