labview 8 for 64 bit system
can labview be installed in 64 bit systems? (say, labview version 😎
(1,518 Views)
Yes. On Windows it will install into the C:\Program Files (x86) folder. This is true for (almost) any 32-bit application installed on a 64-bit operating system.
I'm assuming, of course, that when you say 64-bit system you're actually referring to the operating system, and not, for example, running a 32-bit operating system on a 64-bit CPU. Some people refer to the latter as a 64-bit "system", which it really isn't.
(1,510 Views)
In addition to Saverio's comments, your question is way too vague.
  • Is this under windows or Linux?
  • If Windows, what is the windows version? (64 bit XP, vista, or 7)
LabVIEW 8.0 is very old and obsolete. It is no longer even listed on the LabVIEW OS support matrix.
(For example LabVIEW 2009 is the first version supported on Windows 7 (32 or 64 bit))
Please provide more detail.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
(1,499 Views)
@altenbach,@smercurio_fc
thank you for your inputs! windows 7 64 bit os!
(1,479 Views)
Then you will need to look over all the other questions that people have asked about installing old versions of LabVIEW on Windows 7. Believe me, there have been lots of them. In short:
  • Try running the installer with admin privilege
  • If that doesn't work, you may need to install and run LabVIEW in XP Compatibility Mode
  • If that doesn't work, use a virtual machine
  • If that doesn't work, upgrade LabVIEW.
Sorry, but that's reality. I don't make it, I just suffer through it like everybody else.
(1,460 Views)
