labview 8.2 Compact RIO vi communicating with MAX channels
I am still trying to run my CAN Receive project / CAN Receive host.vi that is linked to MAX. I have created acouple channels and i get a brief (1-2 sec) response but gives me an error. I compile and deploy the vi with no errors. I only get this error when i run it (CAN Receive host.vi):
ERROR 1074388678 occured at CAN Read (Single-Chan Single-Samp Dbl).vi
Possible reason: NI-CAN (Hex 0xBFF6213A)
Why am i getting this error?
What is a solution that i can get this fixed?
Do i need to configure MAX with the project? If so, (per MAX instruction), what is IVI and how do i configure it?
How to get to the receive host vi
Find examples
Hardware inputs
Compact RIO
Module Specific
CAN
985X
CAN Receive Host
(2,879 Views)
Hello MSU-Mankato:
I just wanted to clarify that setting the Interface Virtual Bus Timing to True on the Set Property  and ncSetAttr VI solved the issue for you.
Roland A.
Check out VI Roadshow
(2,849 Views)
