labview 8.0.1 crashes in windows xp
Labview 8.0.1 crashes randomly when running conrol software developed from labview.
Hp xw8200 workstation.
Any ideas anyone?Smiley Indifferent
(2,865 Views)
Do you know the associated error code?  Is it always the same code?
You say "randomly", but what is the program doing when it crashes?
(2,838 Views)
My LabVIEW 8.0.1 also crashes randomly in Windows XP.
It doesn't matter wether I'm developing, the program is running or the application is used.
I am opening tables and showing them on the Frontpanel from a diagnostics software and then it usually crashes.
When I show the tables in a spredsheet-string or a multicolumn listbox the program keeps on going for longer, but after a while it also crashes (or not).
The problem is, sometimes it crashes with the first table I open, or after the fifth or tenth table, sometimes when I close the prog, but sometimes it doesn't crash at all.
The report doesn't give me a hint, all it contains are the names of my dlls and their versionsnumbers ect., all the junk nobody needs.
Does anybody have a clue about why that happens or what I could do against it?
Thank you!
Robert Costello
(2,676 Views)
Have you noticed performance (speed) reduction with your PC lately?
If so, do a thorough virus scan and look for a trojan.
Similar issue happened to me about 2 or 3 months ago.  Fortunately, I had a backup image of my C: drive, which restored everything.  There was a nasty trojan which affected the performance of the PC and caused crashes of Labview and other programs.
R
(2,670 Views)
