06-02-2009 08:40 AM
Hello all,
My executable generated from a labview 7.1 vi Keeps crashing referencing an LValarms.dll. I am runnig on XP sp2 and using a dual core processor. I have read all the threads about this and none fixed my issue. one of the threads references changing the CPU assignment to 0 in the timed loop. i looked for this all around but this option dosent seem to exist in 7.1. any help will be greatly appriciated.
thanks
06-03-2009 06:02 PM
Can you be more specific on the error message that you are getting? The option to assign cpu does not exist in LabVIEW 7.1. That is a function that was introduced in LabVIEW 8.6.1. The LValarms dll is associated with the DAQmx create timing source VI, so your problem might be associated with that.
