label printing through dymo printer
Hello guys,
I am able to print already saved label through vi as given below
But I want to change text of label programmatically through labview and then print it . How can I do this ?
Thanks: Soumya
(3,441 Views)
You can just write a different file using LabVIEW, then print that wit the same code. Is this a subVI? Is the filename a subVI connector? Hard to judge from a picture. We prefer to see the actual VI.
(you can crop your screenshot to the important part. We don't need to see the entre desktop)
(3,435 Views)
Please find the attached file.
thanks,
soumya
(3,426 Views)
Sorry, I am not familiar with your printer.
This is just flat code and no subVI connectors are assigned (and you also fail to close the reference!).
As a first step you need to make it into a subVI and assign the various connectors needed, then call it from your main VI after writing a new label file. Do you know the required file structure?
How does it know about the full path of the file? Does it expect just a file name or a full path?
(3,414 Views)
Hey ,
Now the attached vi can be used as sub vi. I have label. which is a xml file with extension .label . I am not  able to attach label file here . Currently I am changing this label file in labview and then printing it through this subvi . but it doesn't seem right . hoping for some other approach to do this
Soumya
(3,350 Views)
Would you mind please converting both your VI to LabVIEW 2017 ?
Steve
(3,179 Views)
Never mind converting.  Already been done.
(3,132 Views)
