10-07-2020 12:40 PM
Hello guys,
10-07-2020 12:50 PM
You can just write a different file using LabVIEW, then print that wit the same code. Is this a subVI? Is the filename a subVI connector? Hard to judge from a picture. We prefer to see the actual VI.
(you can crop your screenshot to the important part. We don't need to see the entre desktop)
10-07-2020 01:26 PM
Please find the attached file.
thanks,
soumya
10-07-2020 01:36 PM
Sorry, I am not familiar with your printer.
This is just flat code and no subVI connectors are assigned (and you also fail to close the reference!).
As a first step you need to make it into a subVI and assign the various connectors needed, then call it from your main VI after writing a new label file. Do you know the required file structure?
How does it know about the full path of the file? Does it expect just a file name or a full path?
10-08-2020 09:11 AM
Hey ,
Now the attached vi can be used as sub vi. I have label. which is a xml file with extension .label . I am not able to attach label file here . Currently I am changing this label file in labview and then printing it through this subvi . but it doesn't seem right . hoping for some other approach to do this
Soumya
02-02-2021 02:54 PM
Would you mind please converting both your VI to LabVIEW 2017 ?
Steve
02-03-2021 08:52 AM
Never mind converting. Already been done.
