keyboard focus two buttons
I have two string controls and two buttons. The user scan a barcode in the first control and the "Enter" at the end of the scanner signal activate button 1. Now the focus jump to string control 2 and the user can scan a second barcode.
My problem is that I want to set the focus on button 2 now. That the Enter from the scanner activate button 2.
How can I handle this? Is this possible?
regards Schwede
(2,157 Views)
The property node 'key focus' will let you achieve this.
Right click the button, create, property node, keyfocus.
Drop it on your block diagram and wire up a true/false at the appropriate points in the code.
Ian
(2,150 Views)
Yes, I know and use it.
But is doesn`t work on the second button. The focus is still on the first button.
(2,147 Views)
Are you setting the 1st button to false, as well as setting the 2nd button to true?
(2,145 Views)
