key focused cluster controls
Has anyone been able to apply key focus/tab/arrow keys to cluster controls??
(2,672 Views)
You can use the Key Focus Property Node of one of the elements in the cluster to set the focus on something. From there, you can use the tab key and move about the cluster.
Richard
(2,663 Views)
Can you send me a working example?
(2,659 Views)
No LV at the moment. Let me explain the process:
  • On the front panel, right click one of the elements in the cluster - lets say the topmost element - and select Create > Property Node.
  • A Property Node will be created on the diagram. Right click that node and select Key Focus.
  • Change that node to Write.
  • Wire a true boolean constant to it.
  • Put this outside your main loop so that it activates when your program starts.
Richard
(2,651 Views)
Accepted by topic author Newton2this
Find an example below. You can press tab to focus the next control.
(2,645 Views)
Well done!  Thank you, John
(2,632 Views)
