09-04-2005 11:28 AM
09-04-2005 02:12 PM
09-05-2005 07:51 AM
09-05-2005 08:04 AM - edited 09-05-2005 08:04 AM
This doesn't happen only with the time stamp control, but with regular numeric controls as well.
I would describe it like this - The up and down keys always increment or decrement by one, regardless of the number you set for incrementing. I would call it a bug and I think that if you set the incrementing to 15, then the seconds should increase by 15 when you change the seconds value using the up key. The reason it doesn't change now is because you only add 1 and it rounds it back down. If you coerce up, you will see that you can increment.
Message Edited by tst on 09-05-2005 04:11 PM
09-05-2005 08:19 AM - edited 09-05-2005 08:19 AM
Message Edited by tst on 09-05-2005 04:20 PM
09-07-2005 04:00 AM
09-07-2005 04:19 AM
I agree, definitely worse. The control should remember the fact that you modified the fields and not overwrite wat you do. I think this is even more of a "real bug" than the other one. To report this as a bug, select the email option here.
09-08-2005 06:27 AM
09-08-2005 06:33 AM
09-08-2005 06:39 AM
