keithley 2440 source meter, 4 wire measurement
Dear all,
I'm using keithley 2440 sourcemeter to measure the resistance value with 4 wire. I downloaded LabView driver, tested an example program , and
it works fine.
I tried to measure the resistance with 4 wire, so I put the "Enable Remote Sensing.vi" before the "Read Single.vi" , but it generated the error "#803"
which is "Not permitted with OUTPUT off". If I disabled the Remote Sensing, then it works with 2 wire mode.  I'm using LV8.2 and I've attached the program.
Could you help me with figuring out this problem?
Thank you very much.
Yoon
(2,745 Views)
Duplicate thread, check out the solution here.
(2,721 Views)
