keithley 2000/2400 !!! with labview
hello
I need a control program that will enable me to control all the common
parameters of the 2000/2400 and will enable me to set, control and sample
the measurements using the PC.
For example I need a program that will enable me set and run a sweep on the
2400 and measure it with the 2000 using triggers.
* A program that do the following:
# run a sweep with the 2400 - enable the user to configure all the
sweeps parameters
# give a trigger to the 2000,with or without time delay
# the 2000 will sample according to the trigger and store
the samples in buffer or/and send the measurements to the PC
during and in the end.
# the 2400 will be able to also measure his output du
ring sweep
operation.
# all those tests will be done in fast mode .
thank in advance to any one that will answer this add!
motti
(1,891 Views)
It took me about 10 seconds to find the 2000 driver on the included CD. No
2400. Look on NI's website.
Jared
"MOT" wrote:
>hello>I need a control program that will enable me to control all the common>parameters
of the 2000/2400 and will enable me to set, control and sample>the measurements
using the PC.>For example I need a program that will enable me set and run
a sweep on the>2400 and measure it with the 2000 using triggers.>>..> *
A program that do the following:> # run a sweep with the 2400 - enable
the user to configure all the>sweeps parameters> # give a trigger to
the 2000,with or without time delay> # the 2000 will sample according
to the trigger and store> the samples in buffer or/and send the
measureme
nts to the PC> during and in the end.> # the 2400 will
be able to also measure his output during sweep>operation.> # all those
tests will be done in fast mode .>>>thank in advance to any one that will
answer this add!>motti>>
(1,891 Views)
I'd say that you need to read the manuals for
these instruments, and learn how to automate the
commands/controls you've initiated from the bench
to do such measurements....rather than have
someone out on the internet do your job FOR you.
btw, I've done what you describe w/2400 & 2000 (+
a '7001 to switch between multiple DUTs), it's
not that hard to do.
Sent via Deja.com
http://www.deja.com/
(1,891 Views)
Hi
fallowing your comment!
If you think that I'm asking for help without trying myself-that isn't the
case !!!!
first of all I did what you suggeted,and some programs are working right but
I'm still having trouble with the fast reading from the buffers .
second - if you can help me -help, it will save me a lot of time (I mean a
lot) .
third - maybe my add wasn't so clear but still you don't need to be so
negative.
bye
MOT
wrote in message
news:967o3r$764$1@nnrp1.deja.com...
> btw, I've don
> Sent via Deja.com
(1,891 Views)
