is there any way to make an external SPST pushbutton act as a Latch when Pressed button?
Hey,
I just wanted to know whether or not there is there any way to make an external SPST pushbutton act as a Latch when Pressed button? I have about 10 pushbuttons that can be pressed, and upon the press, a TTL signal is sent into LV. I want to be able to have each pushbutton push activate a valve for a certain amount of time (approx 300ms). The programming for the valve control is worked out, I am just running into a problem when the user presses and continues to hold the pushbutton for more than 300ms because this causes the valve to open a second (and third, ...) time. Is there any way to solve this problem in LV. Thanks.
JOe
(2,618 Views)
Hi Joe
I attached a simple example how you could do it.
If a button is pressed, just react on the rising edge. Use this to start a timer which enables another signal.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,612 Views)
Thomas,
Thanks alot. It works perfectly. That never would have crossed my mind. You saved me a boat load of time.
Thanks again.
JOe
(2,590 Views)
