03-11-2010 10:48 AM
I'm trying to measure the dc resistance of an RTD vs. time. My requirement is to determine the time it takes for the sensor to reach 63.2% of final resistance value following a step change in temperature from room ambient to water at 150F flowing at 3 ft per second.
It occurred to me that response time is a fairly common measurement so I was wondering if there is an express VI or something already written by someone that I could use for my application rather than write a new program.
03-11-2010 10:55 AM
03-11-2010 10:59 AM
03-11-2010 11:31 AM
Depending on your needed accuracy and how stable your bath temp is you need to define final value ....
I think that is the more tricky part. The rest is collecting the data and find or interpolate the value you search.
If you can assume an exponetial (or whatever descriptive formular) curve you might get a better and faster result with curve fitting (parameter identification, levenberg -marquardt, ...)
03-11-2010 11:39 AM
