06-20-2008 09:04 AM
06-20-2008 09:09 AM
06-20-2008 09:48 AM - edited 06-20-2008 09:51 AM
06-20-2008 09:51 AM
I can't post the code...or send it to you.
Let me build a sample on the same machine and see If I can reproduce the effect. In the mean time I will make sure the case T/F definition is connected to the right terminal. If It is supposed to work, then I will look elsewere for the problem.
Thanks.
06-23-2008 05:28 AM
06-23-2008 06:53 AM - edited 06-23-2008 06:53 AM
06-23-2008 01:25 PM
I am working on the example to try and construct it as I am using the features. It will take a bit.
Thanks...It may very well be a history issue...it it pretty reliably alternating between the present value and the past value. Let me play with it a bit and then add to this thread if I figure out what is actually happening.
06-24-2008 09:52 AM
06-24-2008 10:22 AM
06-24-2008 10:27 AM - edited 06-24-2008 10:31 AM
