04-14-2009 01:03 AM
hi...
i need to tab through the active cells which are already not seen on the table. i mean i can only tab through the cells which i see, i need to use the horizontal scrollbar to move to the cells which are not already seen.
can i programmatically change this behaviour?
i used the example program below to disable a part of the table.
http://zone.ni.com/devzone/cda/epd/p/id/2163
then i noticed this behaviour. hope its the same with arrays also.
please reply with your valuable suggestions
thanks in advance
Renn
04-14-2009 01:56 AM
Hi Renn,
you can use the event structure to react on the tab key. There you can use the property "top left cell" to scroll the table programmatically.
Mike
04-14-2009 02:06 AM
hi mike
i dont see this property. i'm using LV851. could you please send me a screenshot?
thanks
04-14-2009 02:50 AM
04-14-2009 02:54 AM
04-14-2009 03:44 AM
Hi Renn,
maybe the name has changed.
See the attached vi for the property a mean.
Mike
04-14-2009 03:50 AM - edited 04-14-2009 03:53 AM
04-16-2009 02:01 AM
