12-15-2006 03:56 PM
Hey All,
I kind of getting interested in this. Why do you need arrays for data values?????
If you are comparing only one process value at a time..
Correct me if I am missing some part of the problem.
Regards
12-15-2006 04:46 PM
12-15-2006 06:36 PM
12-15-2006 06:39 PM
hi
i am still in the process of fixing my code......
any help is highly appreciated...
thanks in advance
radhika
12-15-2006 07:23 PM
12-17-2006 12:11 AM
12-21-2006 01:15 PM
Hi all,
Thanks a lot for all your replies.My simulation worked successfully by following the steps you all have referred.
Thanks & regards
radhika.
12-30-2010 09:07 AM
Hi buddies,
i would like to use 'if' condition in labview, like if i=1, 1st operation.... i=2, 2nd... i=3, 3rd operation... then when i=4, it should again go to loop 1.. i mean i=1..
How is it possible... help me out guys..
Thanks in advance 🙂
-Ranjita
12-30-2010 09:24 AM
The Case Structure is the LabVIEW equivalent of the if - else construct in text based languages. Read in the manual how to set the cases to react correctly to your input variable.
If you're not familiar with it you need to go through the LabVIEW Tutorials. All types of program flow control are covered and there are some good examples: http://zone.ni.com/devzone/cda/tut/p/id/12302
12-30-2010 11:52 AM - edited 12-30-2010 11:53 AM
You could use the poor mans's sequence structure, e.g. as follows. Not very flexible, though.
