is it possible to transfer update record to another database table ?
Hi all.
Is it possible to transfer updated record from a database table to another database table in MS access ??
Eg. A updated record from 'Student' Table , Transfer that record to the 'Attendance' Table and that record is deleted at 'Student' Table.
Which mean the record is moved from 'Student' Table to 'Attendance' Table.
(2,621 Views)
Accepted by topic author ChongKit
Yes.
You need to INSERT into the other table and DELETE from the original table. Both of those words in caps are T-SQL commands.
There is no "transfer" command.
(2,620 Views)
Oh i see..
I will start to work on it then.
Thank alot for your help 😄
(2,618 Views)
