interrupt states in a state machine
You find in the attachment two versions of my work : the first one with QMH and the second one with simple state machine
So i want doing the following process :
1--  i clic on "start measurment button", the state machine executes seq1 until seq4 normally unless i didnt clic on "stop measurement button" . i want when i press on "stop measurment button" the state machine interrupts the execution of the sequences and executes the "stop device state" and then returns the wait for user event state.
2-- i want to calculate the execution time of every state of my state machine
3-- i want that the current time to be dynamic  and  not fix
Plz heeelp
(2,249 Views)
Accepted by topic author JASMIN185
What happens in the sequences steps? Currently you cannot abort during a state, just between states.
You can update the time display if each state uses the outer loop until a time has elapsed to go to the next state (or idle if the process is interrupted). If you want a continuous time display, it needs to be in a separate loop with a reasonable constant loop time.
A quick band-aid fix would be to pass the state through a select function before the case structure and switch to idle if the a button ins pressed. (f each state calls a lengthy subVI, you can jump through some flaming hoops with references to the time display, but I would not recommend that)
Get rid of the event structure!
(2,233 Views)
* in the sequences steps i send configuration to the instrument and i wait for it to finish calculating the leaking current and i display the result in the front panel . the same process is repetaed with seq 2 , 3 and 4 . parametres is the only thing that make diffrence betwwen sequences . and YES i want to ABORT the state execution once i clic on stop measurment button because every sequence state takes time ( about 1:30min) to finish executing
** i put the time display in a separate loop but once i clic on exit button the labview program continue its execution ( see image bellow )
***f each state calls a lengthy subVI, you can jump through some flaming hoops with references to the time display, but I would not recommend that) can u explain more ?
thank youu
(2,196 Views)
Put an event structure with a 500ms timeout and stop value changed event in the small loop and it will stop too.
(2,191 Views)
