intensity of lights/led
Is it possible to control intensity of a led using sine wave or cosine when you have LV interfaced with Arduino? Basically to make it glow slowly by time and then intensity should decrease on its own with certain paatern of the signal or wave generated?
Thanks.
Message 1 of 8
(3,813 Views)
From the hardware standpoint, you can change the intensity of an LED by varying the current through it. How you do that, depends on how you system is structured.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,801 Views)
Thanks Mike for your reply.
Yes indeed, through hardware it is possible but what I'm trying to do is if it could be possible in LV code.
for example using PWM pins of arduino it is possible to have different duty cycle but what if intensity increase or decreses with sine wave i.e. it varys with the curve, something like that.
thanks
Message 3 of 8
(3,746 Views)
If what you're asking is whether you can generate a PWM output, the answer is yes.
LabVIEW Champion
Message 4 of 8
(3,736 Views)
I think I couldn't explain it well.
 I am asking whether it is possible to control brighness/intensity of the led using a sine wave or bell curve etc?
For example; when LED is switched on (or when program runs) it should automatically slowly reach to its max intensity by the time?
Message 5 of 8
(3,719 Views)
Yes.  You just need to translate the value of the sine wave at a point of time to a PWM value to pass to the Arduino.
Message 6 of 8
(3,717 Views)
and how it could be implemented?
Just using the sine wave generator and connecting its output to PWM of arduino ?
Message 7 of 8
(3,714 Views)
Sure.  You may have to do some scaling.
At some point you are going to have to just start programming and trying things out.
Message 8 of 8
(3,706 Views)
