integrating plot multi x-y vi's and three dimensional graph vi's
i wish to plot a three dimensional graph of multiple data points (there is no formula or math function involved so currently simulated using dc signals). i used plot multi x-y vi for acquiring the points but it is in "2-d picture" format. i used 3-D surface graph vi for graph generation which is in a different format. can i integrate the two somehow or is there any other way out?
(3,012 Views)
To plot multiple x,y curves in 3D use the 3D Curve.vi
The attached example demonstrates using 3D Curve.vi to plot several time varying curves.
I hope this helps
Kurt Friday
www.sciware.com.au
(3,000 Views)
hi Kurt, thanks for your reply.
(2,982 Views)
hi, i have another query. can i get a three dimen. thermal heat flow model of a cuboid structure by further modifications in this vi itself?
(2,980 Views)
It depends on how you want to visualise the data. Can you provide more information please?
Kurt Friday
www.sciware.com.au
(2,970 Views)
