04-13-2016 03:09 PM
I don't have Vision installed on my dev computer so I can't show a proper screenshot.
Basically you want your subVI to take a control reference for output array and a control reference for Image as it's input.
Inside your subVI, you'll write to the control references. Every time you write to the control reference in your subVI, the changes will be reflected in your Main VI.
Something like this:
Except you should also have a Image Ctrl Reference going into your subVI.
04-13-2016 03:10 PM
Use a Queue or Notifier to get values from a running subVI, references with property nodes can be problematic, do not go that way.
04-13-2016 03:30 PM
Can you also attach the screen shot of Subvi block diagram also. Just the main part is enough.
Many thanks
04-13-2016 03:36 PM
Blokk is right that this is almost certainly the wrong way to do this.
Your subVI is going to have elements like this.
Really though, go back and read the whitepaper.
