09-05-2014 01:36 AM
hello everyone, what I'm trying to do is show values above or under a value that I choose of a continuous signal that varies from 10 to -10 .From these I would like to show only values above or under a value of my choosing. For example that values only them look (above / under) of +5, to -5. (Thing that I already have resolved, maybe not the best). -> And to indicate how many times there is a higher or lower value than these.
I attached my .vi that I have. If anyone can help me because I have trouble doing this.
09-05-2014 02:21 AM
Some comments:
See attached modification (LV2012)for some ideas.
09-05-2014 02:22 AM
I could not open your vi ( have 2009 )
But see if you want this.
I think you are getting data from some sensor replace input value with that.
09-05-2014 02:29 AM
And here's how to count how often he value is above or below a certain limit.
09-06-2014 10:57 PM
I really appreciate that you take a time to solve my trouble
and I'd like to know if there are any problem to choose" use default if unwired" because when I run my original code, this works good (apart of the explanation in point 2)
I probed with the function max & min ,too with the same structure and I choose "use default if unwired" and I attached the other vi because I think the solution to my question can be useful to both and yeah the function max&min is less code
now I try to detect a peak could you check my code. I have problem to represent the peak on the graph
09-06-2014 11:10 PM
and if other take the time to help with this. Your responses will be well received ,too
09-08-2014 08:30 AM
Hey there;
So if you chose to use default if unwired in the cases where the button read is not pressed you will get the default value (cero) I believe that is the expected behavior in you program;; or you might also want to wire a NaN constant instead.
You could use the InRangeAndCoerce VI; this VI will tell you if a signal's value is between two desired limits and will give you a TRUE boolean in case they are not.
By the way; i you will be using a DAQ Assistant instead of your "Random Number" make sure you configure it to 1 sample software timed.
Hope this helps
Cheers
