12-11-2014 03:10 PM
Is there any reason why I shouldn't be able to use in range and coerce on time stamps? In this VI the value is not being coerced, but the output for in-range is false. With values out of range, it DOES coerce the output.
Solved! Go to Solution.
12-11-2014 03:13 PM - edited 12-11-2014 03:16 PM
Making the possible error of replying without first testing... is it possible the problem is that you have the upper and lower limits swapped? Timestamps are numbers, and later dates are larger numbers. Since 12 is greater than 8, the upper limit should be 12/11/2014, and the lower limit should be 8/11/2014.
EDIT: after testing, yes, that's definitely the problem. Swap your upper and lower limits and it will work as expected.
12-11-2014 03:21 PM
:manembarrassed:What a NOOB mistake!
Thank you nathand
12-11-2014 05:14 PM
Thank you nathand
LOL The next noob minstake is forgetting to mark the person's post that solved the issue for you as the solution. 😉
