in place element structure doesn't support rows or columns for 2D arrays?
I went to use an In Place Element Structure today on a 2d array of strings.  The plan was to wire that into a subVI which would modify the elements of the table column (17 in total).  I was planning to use another In Place Element Structure which would handle the rows of the selected column.
But it doesn't appear that In Place Element Structure supports pulling a row or column from a 2D array.  Am I missing something?  I could not use a subVI with antoher for loop, but it would make the code less attractive and destroy my Modularity Index.  I guess I will have to do it the old way unless there is some option I haven't found.
(2,500 Views)
I noticed that a while back, too.  I'm guessing it's because there's no way to guarantee that the row/column you pull out will stay the same size after being manipulated within the structure.
-D
(2,497 Views)
