imaqdx configuration on Windows 7
Hi all,
after downloading the vision acquisition software and IMAQDx (version 9), can someone tell me how do I configure it on Windows 7?(I am currently using  LabView 9)
(1,911 Views)
I'm not sure I understand the problem.  I assume you have an installed version of LabVIEW 2009 on your machine, and have downloaded the Vision Development Module for LabVIEW 2009.  You need to install it, as well -- there should be a Setup application that will handle this for you.
Once this has finished, you should see the Vision functions on the Block Diagram palette (you may need to make this sub-palette Visible).  You can now add the Vision functions to your Block Diagram.  Note that to connect to a Camera, you will probably need to add the appropriate Drivers, as well.
BS
(1,878 Views)
