imaq vision driver for frame grabber
Highlighted
for image aquisition in our lab i use the PCI 1408 frame grabber which
works fine but is quite expensive. in some applications i don´t use all
the features (triggering, multiple cameras, different video formats).
therefore i search a real cheap hardware solution for image aquisition
for use with imaq vision and labview.
is there a driver for the simple frame grabber cards you can buy
together with web-cams (based on a brooktree chip bt848 or bt878)? if
not, is there a driver for cameras you plug in on a usb connector?
if there is no driver: anybody got information/manuals i can download
about the data format imaq vison needs for aquired pictures so that i
can programm a driver on my own? (i couldn´t find anything o
n the
ni-website).
thanks for your help
herbert
(1,717 Views)
Highlighted
> Herbert,
I am using the cheap "falcon" frame grabber which is available from several
vendors. It comes with a powerful DLL which can be linked easily to LV and
imaq vision, no need to know which chip is underlying (the Bt848 by the
way). A simple C-code moves the video image to an imaq image, all within
the LV environment.
Best wishes,
Detlef
(1,717 Views)
