Hello all,
Sorry if this is a repost of a question previously asked. I can't seem to find it in the forum.
Basically, I have a background subtraction vi that takes a bg image and subtracts it from a realtime (RT) snapshot image. The problem is, I can only display the subtracted image and not the snapshot. I've tried converting the RT image to an array and recover it with a new image name, copy it to a new blank image under a different name, but nothing seems to work.
However, strangely enough, if I don't attempt to branch the RT image to a display in the front panel and probe before and after the subtraction routine, they appear fine!?!?
Any help would be greatly appreciated. I've attached my vi's in a zip file. MAIN.vi is the main program to run.
I believe you will need the NIVISION ACQUISITION package to view it properly.
Anderson Chen
