You might consider using a picture control instead. The VIs are straight forward, and the image will come through in real colors. If you need the functionality of the intensity graph, you can specify the color map to get more realistic colors. Try searching the web for info on your save format so that you can extract the color information from your file.
Jeremy Braden
