Hi
I am using labview 7.x with pci 6013 and imaq1407 and am grabbing images using a camera which is at some angle to the image (flat/horizontal).As we know,a circle looks like an ellipse from an angle and some perspective correction can be done to get the actual image(circle) back.Does anyone know how to do this ? My images are not circlular ,but I hope I can apply the same correction for all the images (which look tilted).
I am working on these vis right now and am attaching those here .I am using following subvis:
imaq learn calibration
imaq set calibration info
imaq correct calibrated image
Output of the "imaq learn calibration" subvi is "calibrated image".But it's not calibrated image in literal sense,it's just an image that is being used to learn calibration i.e. it is a calibration template not a "calibrated image".Even the image that comes out of "imaq set calibration info" is called "calibrated image" , but it is not.It is the output of "imaq correct calibrated image" that looks like a calibrated image.But sometimes it is upside down or rotated.
Is there anyway I can eliminate this rotation ?
Thanks for sparing your time.
Cheers
Deepak
LAB View 2010 SP1
