10-20-2016 08:05 AM
I am tring to get a specific data output from my DAQ.mx, but when my data is over i need it to stay in high voltage. How can i do it?
thank you.
Adi
Solved! Go to Solution.
10-20-2016 08:13 AM
10-20-2016 08:51 AM
actually i'm talking about analog output, i attached a photo.
when my waveform ends, i need the output to be on voltage that i define (not 0).
i know there is a function of idle state for miHSdio that called - configure idle state.
thanks for your quick respond.
10-20-2016 08:57 AM
Hi Adi,
What happens when you define the last sample to have your HIGH level value?
HSDIO is totally unrelated to analog outputs…
Which kind of hardware do you use? What does the manual/specs tell about the feature you try to implement/use?
10-20-2016 09:40 AM
You were right, I set the last sample to the high level and it works.
(by the way, I'm using NI PXIe-6363)
thank you very much!
