10-01-2008 05:01 AM
In a C program, for instance, I would initialize a GPIB device using
DeviceID=ibdev(...) and ibclr(...)
and for uninitializing an ibonl(DeviceID,0) would do...
Now my question is: what are the LabVIEW equivalent to these functions, and where are they to be found? In particular ibdev and ibonl?!
Help will be much appreciated!
Mathieu
10-01-2008 09:00 AM
10-02-2008 04:03 AM
Thank for your comment.
I indeed know it is not completely equivalent, however I am in front of a communication error between two GPIB devices when using LabVIEW, and I would appreciate to test it step by step as I would in, say, LabWindows.
I am not familiar with VISA though, which improvement does it bring? What is it basic working scheme/programming flow idea?
Mathieu10-02-2008 08:57 AM
VISA is an API that sits on top of GPIB, serial, and TCP/IP. It's intended to be used so you can easily switch between protocols using the same instrument driver. This is intended to make it easier for programmers to deal with instruments that have multiple communication interfaces. You can get a basic overview here.
As for your specific issue: What instruments are you dealing with? Do you have instrument drivers for them? If not, have you looked in the Instrument Driver Network? Try to follow the steps outlined in this KB article: Instrument Control in LabVIEW Tutorial. Have you verified that you can communicate with the devices using MAX? My guess is that you're probably missing a command termination character, like a carriage return or linefeed.
