Hello LabVIEW gurus! Problem Description:Actually, I work on a VI for a PDA (iPaq5550 & DAQ6062E) for a data acquisition of 16 channels (@100Hz) and a following transmission through a WLAN-connection (TCP/IP) to a client. In more detail, between the DAQ and the received data at the client there is a time delay of about 2.5 to 3 seconds which I wasn't able to solve. I tried to reduce the source code to a rudimentary construction where only the raw data of the 16 channels (INT16 values, 1D-array, 100samples/channel) was sent one time per second directly over the network connection. There was no parallel file writing process, graphs or anything else.
Questions:1. Is it possible, that the problem occours because of the performance of the used PDA in combination with a multichannel DAQ?#
2. Do you know a method to reduce this time delay to guarantee a "live" preview of the data e.g. on a laptop?
3. What network protocol should I use instead of TCP/IP?
Thanks a lot for anwering my question(s)!
Greetings from Vienna,
Philipp Kornfeind
University of Vienna
Institute of Sport Science
Section of Biomechanics, Kinesiology and Applied Computer Science
