08-15-2012 02:49 PM
Hi
please copy logo.png in c:\windows then use project
08-16-2012 08:57 PM - edited 08-16-2012 08:59 PM
Hi.
I download your project called "Map with GPX LV 2011" but I have a problem when I run "Create Route.vi".
I have the error 1172 in GMap.NET.MapRoute (points and distance). That a error terminal with the name "sortie d'erreur".
I do not why the error appears. When I ran a time later the VI works perfectly but I do not know why it do not work right now.
I formated the computer, I installed and unistalled the .net framework 4, I am working with .net framework3.5, etc. and the "create route.vi", not work.
I am working with LabVIEW2011x32 in a x86 with WinXP and LabVIEW2011x32 in a x64 bits with Win7 too (2 computers).
Can you help me with any suggestion??? It is really important for me because I will need to present a university project. I need to use routes is gmaps.
Best regards.
Juan Andres.
08-20-2012 02:48 AM
Hello Juandres,
This VI was created by me, not by M. Garoussi. I tried to use the function "routes" from the .NET library without results. In the project you downloaded, you can load GPX files and visualize it on the map. That's the only function I added to the project.
I used a French version of LabVIEW that's why you have "Sortie Erreur". it means "Error Out".
For the routes function, the problem seems to come from the gmap provider properties. You can try to find a solution by searching in the .NET project.
Good luck.
Maxime R.
CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
CTA - Certified TestStand Architect / Architecte TestStand Certifié
11-02-2012 11:20 AM
Hi M.Garousi.
“use this project and xcontrol : http://www.4shared.com/rar/aj8vN8WZ/Gmap_Xcontrol_New.html”,the file can not be downloaded,because “Gmap Xcontrol New.rar' is unavailable. the file has been deleted”,
can you please upload it again?
I downloaded the file ”GMap.zip“, but when I ran it an error occured. I don't know why. Can you give me some advice?
thank u very much!
keith.huang
12-03-2012 09:39 AM
Hi Francois,
I can not donwload Mr Garoussi project from 4shared: http://www.4shared.com/rar/aj8vN8WZ/Gmap_Xcontrol_New.html.
Can you please send me please?
Email:zxhero6@163.com
thank u in advance^_^
Keith
03-12-2013 08:55 AM
Hello, M.Garousi. I'm a student in a university of china .I can't download the GMap.zip. Can you send it to me by email. My email address is 812303306@qq.com . Thank you
M. Wang
03-12-2013 08:55 AM
M. Wang
03-13-2013 08:56 AM
Try to download GMap.zip from M. Garoussi : http://www.4shared.com/file/YyTfhSV1/GMap.html
Regards.
Maxime R.
04-03-2013 10:08 AM
Hello, M.Garousi. I'm a student in Indonesia Computer University, i get error like this :
i have connected to internet, please help.
sorry if my english is not good. 😄
Thank you
04-04-2013 08:25 AM
