05-06-2019 04:17 AM
i am having two different programmes i want to combine these two programmes and run together in one VI file can u help me with this how can merge two programmes. here i attached my two programmes. using LabVIEW 2017 32-bit version
thanks in advance
Solved! Go to Solution.
05-06-2019 04:23 AM - edited 05-06-2019 04:23 AM
05-06-2019 04:28 AM
i would like to connect these two programmes such that when i change the distance(i.e move piezo) there should be a change in spectrum. can u help me how to connect in that way
05-06-2019 04:29 AM - edited 05-06-2019 04:29 AM
If you want them to open separately, you can use the VI Properties to set them to Open when Called, then place them in a single VI as GerdW describes.
If you want to place controls and indicators on a new VI and have them read inside the existing subVIs, you should look at using either Queues or Notifiers to transfer data into (and out of) their loops.
Documentation for those can be found here: What Is a Queue?, What is a notifier?.
05-06-2019 04:35 AM
Haii
can u please attach an example vi representing my problem. so that i can follow accordingly.
best regards
05-06-2019 04:45 AM
