09-17-2007 04:17 AM
09-17-2007 04:33 AM
09-17-2007 05:07 AM
Hi ,
Thanks for your prompt response.I don't understand why it is hapening in one case structure and not in rest 3 case structures which are simply replica of that case structure.
I will try to do what you have suggested but again my doubt lies there as the feature should remain same for all four case structures which is not happening.
Regards
Sarita
09-17-2007 05:29 AM
Sarita,
Post your code for us to have a look at it n review.
09-17-2007 10:25 AM
@MindPower wrote:
I am using a case structure and within that ,in one casse ,it is disabled & grayed and no data should traverse through it and in second case ,it is enabled and data should traverse through it.
Simply place the chart terminal inside the case structure. No fancy property nodes needed.
I don't understand your description with the 4 case structures. Do you have 4 different charts? What "works" or doesn't "work"? Disabling an indicator should never work, ever. 🙂
09-18-2007 02:18 AM
