03-21-2006 04:07 AM
03-21-2006 08:28 AM
The information you've provided is very confusing. You first say you want to use NI-DAQ and then in the second you talk about using the Instrument I/O Assistant. They are two completely different things. NI-DAQ is for pc data acquisition boards from NI. How is this "apparatus" connected to your computer? If it's serial or GPIB, then the Instrument I/O Assistant can be used. It kind of sounds like you might be attempting to use the assistant with a serial connection and that another program is running that also is using the serial port. If you have Hyperterminal or any other program talking to the instrument, you will have to close them first. Windows doesn't allow two different programs access to the same port.
Follow the directions in the on-line help under the "Publishing VI Front Panels on the Web" topic.
