10-22-2012 01:04 PM
A framing error typically points to a setting that is not right. Double check your serial settings.
10-22-2012 01:27 PM
@KPRO wrote:
Attached is the screen shot of the LV. Thank you very much for your help.
Please post the actual code! Many of us will not open an attachment in a propriatary format (Word docs can get easilly infected with viruses)
10-22-2012 01:29 PM
1. 2 bytes is number of byte counted when reading (I did not set this)
2. I did try to set the input buffer larger 1045, but still reading only 2 bytes
3. Double check serial port setting but not much luck
Well, Thank you very much for your help, I need to do more research for this.
Khanh
10-22-2012 02:23 PM
I should've spotted this immediately.
The garbage returned in the VI should've prompted me to look at your hyperterm screen shot. The baud rates are different. Fix that and it should work.
10-22-2012 03:11 PM
Thank you very much. You are absolutely right ... It's working now
10-22-2012 03:38 PM
billko wrote:The baud rates are different. Fix that and it should work.
You mean it really was a serial setting. Wow, I sure wish I would have said something earlier.
10-22-2012 05:40 PM
@crossrulz wrote:
billko wrote:The baud rates are different. Fix that and it should work.You mean it really was a serial setting. Wow, I sure wish I would have said something earlier.
LOL you're rarely, if ever, wrong... but in order to figure out that you were correct, we had to travel a long and winding road... 😄
10-23-2012 01:19 AM
Hi
Please Check With this
https://decibel.ni.com/content/docs/DOC-16283
Prabhakant
