05-01-2011 12:25 PM
Can we write help messages in LABView VIs? Like there will be a tab written manual on it. Whenever it will be clicked, a message will pop up showing the given instruction.
Thanks in advance
05-01-2011 08:24 PM
You can do lots of things. It all comes down to how much effort you are willing to put into it. You can go to the Documentation page on a control's properties and enter in a tip strip which will appear to the user when they hover over a control. You can also create a whole help manual that you can open via a menu item or button. If you do a search for writing help manuals you will see that this has come up. The easiest thing to do is to create an HTML-based manual. You can also create your own popus, if you wish. The Example FInder (Help -> Find Examples) has some popups.
05-02-2011 03:06 AM
Thanks a lot... I''ll definitely go through the examples and will give you feedbacks.
Regards
