how to use regression
i have a two data which forms a cluster of two elements, which in turn is then connected to a graph. However, the line plotted in this graph is not the best fit line. Hence, i decided to include regression. However, there is always the problem that my original data is of dimension 1 and the regression sub-vi is asking for a 2D data. When i insert build array, it does not seem to solve the problem. So, how do i solve it?
(2,415 Views)
Hi Adeline,
if you are using a 1-D line fitting algortihm, then it should be asking for two 1-D arrays. One is the X-array, and the other the Y-Array. If you have a single set of data which is equidistant, beginning with zero, then you can "manufacture" an X-Array with a simple for-loop.
Since it sounde like you're plotting on an XY graph, you should already have X- and Y-Values in your code. Try connecting them both up as 1-D arrays. If this doesn't work, look for a 1-D line-fitting VI.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,410 Views)
Hi Adeline
Besides best fit, there are other solutions that can work fine with your data.
Try smoothing, you can download a vi from www.sciware.com.au (Savitzky-Golay smoothing filter for non-uniformly spaced data. )
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,399 Views)
