03-20-2014 09:43 PM
I want to transfer a float number to a boolean array? How can I achieve?
Solved! Go to Solution.
03-20-2014 09:56 PM
Just refer to the example in this link: http://digital.ni.com/public.nsf/allkb/DD5AFE8E829DC16D86256BDF005E1F95
Hope that helps
Warmest regards,
Lennard.C
03-20-2014 09:57 PM
03-20-2014 10:02 PM
output through NI PCI 6541
03-20-2014 10:06 PM
thank you so much!
03-20-2014 10:10 PM
another question: how can I thransfer a decimal to a 16bits binary number?
03-20-2014 10:27 PM
I would suggest that you should try it yourself before asking those questions. My suggestion is that you should play around with the example from the link I have sent to you and read the explaination in it as well.
Warmest regards,
Lennard.C
03-20-2014 10:40 PM
'Number to boolean array.'
03-21-2014 12:14 AM
but actually "number to boolean array" can only transfer a integer or fixed-point number to boolean array , not float number
03-21-2014 01:06 AM
Just typecast the DBL to U64 first.
