10-30-2014 07:41 AM
I have several VIs runing at the same time. I wish to active one of them time by time and have its window show in the front desktop by clicking it at taskbar. But I cannot.
Say, I have one VI's window full of the desktop (maximize), sometime other VIs window behind it. Then I always have to minimize the big window VI for showing out other VIs window. How can I solve this problem.
Thanks.
WT
LV2013SP1
10-30-2014 07:46 AM
You have to set the property of the front panel window to be displayed as "floating" in windows appearance, so that you can access any window any time.
10-30-2014 07:56 AM - edited 10-30-2014 07:57 AM
I do set it as floating. I mean if I can see a part of the VI window, I could active it to the frontend by the click the window. But if I cannot see it, I cannot take it to the frontend by clicking the tab at the taskbar.
10-30-2014 10:18 AM
I forget to mention that I am using WinXP OS.
11-03-2014 10:54 AM
Have you checked if WinXP is 32 bits? If it is 64 bits it might give you issues due compatibility.
11-05-2014 07:44 AM
My winxp is 32-bit.
After I set all VI's windows behavior to default, now it works OK.
Thanks.
WT
LV2013sp1
