how to take circle attributes seperately
Hello all,
I need to group the attributes(like radius, center x, center y) of circles from IMAQ Detect Circles function. For instance, all of the y positions need to be grouped in an array. I could not seperate them.
I tried a few things to do that. I'm adding my last try as attachment. Because I am new at Labview it may be not a good way. If it is not a good way to do this task, I would be pleased to hear different methods or modifying the VI would be appreciated 🙂
Message 1 of 8
(3,627 Views)
Accepted by topic author sevincom
@omersevinc wrote:
Hello all,
The IMAQ Detect Circle vi returns an array of clusters. Each cluster contains a position cluster with X and Y information (single precision float), the radius (double precision float), and the score (double precision float). You can separate these out by first getting a single element from the array. In the snippet below, I use an indexed tunnel in a For Loop to do this. Then use the Unbundle by Name function to separate the three elements of the cluster. You'll need to use the Unbundle by Name function again to pull out X and Y from the Position Cluster. Then just run all values out of the For Loop with an indexed tunnel and you have it. Hope this was what you were looking for.
All statements are my opinion and worth every cent you paid for them.
Tom Whitaker, CLD
"Give every man thy ear but few thy voice."
Polonius in Hamlet.
Message 2 of 8
(3,602 Views)
Actually, the second unbundle by name is not needed. Clusters within clusters can be unbundled directly.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(3,579 Views)
Thank you both for your helps. I did it like you explained.
I don't know do I need to open a new topic but now I have another problem with circle detection. As you can see from the image, I have only 6 circles. But the function detects 12 circles. It detects each circle twice with small differences. What should I do to constraint the second detections?
Message 4 of 8
(3,550 Views)
Hi omer,
in your picture I can see 12 circles: 6 black ones overlaid by 6 white circles… 😄
Message 5 of 8
(3,546 Views)
GerdW,
You are right Smiley Happy but I need to detect only the black ones
Message 6 of 8
(3,538 Views)
Hi omer,
group the circles by their XY coordinates and choose the bigger one of each pair…
Message 7 of 8
(3,533 Views)
GerdW,
I was looking for an option like find best edge in VBAI but sorting also works for now Smiley Happy
Thanks for your help.
Message 8 of 8
(3,503 Views)
