how to synchronize two PCI 5114 digitizers
Problems are met when we try to synchronize two PCI 5114 digitizers.  we are using the example vi "niScope EX 5112 Synchronization.vi" with labVIEW,  but it doesn't work.  Figure 001 shows the error, and figure 002 show the error after i remove the property nodes on the block diagram. i doubt if there are something difference between the two types of digitizer.  We have the RTSI cable with us and the TClk mode works fine. but we couldn't use the TClk mode because it doesn't support RIS.
Any help? maybe code example is the best. thanks.
(2,072 Views)
i am sorry to post it again here for not selecting board,  i want to post it to "high speed digitizer board". will someone help me to move it? thanks.
(2,069 Views)
